Home › Forums › Products › Rackmount › H800FW: “New OS detected, return to factory default ?” › Reply To: H800FW: “New OS detected, return to factory default ?”
September 16, 2010 at 8:22 pm
#131943
So:
you should probably advise that 5.5 update is possible just with the card. On the current instructions it is written you can choose between card and serial cable.
Also, given that we cannot trust the 5.5 revision name, how do we know we have the correct 5.5 installed ?
probably the OS' date you can read under setup/service/info ?
which is the correct date we should find there ?
thanks,
Luca
