Home Forums Products Rackmount Eclipse Preset Numbers Reply To: Eclipse Preset Numbers
#131999
    DBurris:
    are these preset numbers how off limits or can I still use them?
    You can still use them, but may confuse yourself – I would suggest that you don't. It is possible that MIDI program loading may go astray if you have two presets with the same number.
    DBurris:
    Is there any way a future point release can expand the number of external slots available
    Obviously anything is possible, but it is unlikely, as the current number seems enough for most people.
    DBurris:
    is there any way for me to override the "factory preset" designation on some of the presets
    No. These are set in stone so as to protect them from changes.
    DBurris:
    Do you have recommended procedures that have worked for other customers for shuffling presets
    Using CF cards is probably the easiest.
