Home › Forums › Products › Rackmount › Need Help Routing H8000FW with audio in Logic 9! › Reply To: Need Help Routing H8000FW with audio in Logic 9!
Hey Nick,
Here's where I'm at:
In my SOUNDS menu on the iMac, I have EVENTIDE DICE selected as my main input/output. I've also created an aggregate device for Core Audio, which I have selected in Logic.
My H8000FW hook-up is:
ANALOG 1 IN = preamp
ANALOG 1 OUT = L speaker
ANALOG 2 OUT = R speaker
In regards to H8000FW routing, I have selected preset program #27 (Analog&Firewire AB). I get clear signals when I play software instruments. When I try to record live audio, I don't get any signal out of my speakers, although there is a clear level registering in the Eventide, as shown on the front meter.
When I select preset program #10 (Analog AB), I cannot playback my software synths, but I do get a clear audio signal out of my speakers (from my mic). Still however, I cannot record into Logic, as it is not receiving any information from the Eventide since firewire is not part of the selected routing program.
Based on this, I have a routing question that might be the key to my audio issue:
How do I configure my H8000FW routing so that I get a clear audio signal (like I am getting with routing preset #10) WITH firewire enabled? I'm assuming the stem of my custom routing will be based on #27 (since it enables firewire and analog signals). I've tried all the other firewire presets and the only one that receives any audio signal INTO the Eventide is #27, although there is no audio signal coming out of my speakers.
I must be really close! Any suggestions?
