Home › Forums › Products › Rackmount › Need Help Routing H8000FW with audio in Logic 9! › Reply To: Need Help Routing H8000FW with audio in Logic 9!
September 28, 2010 at 10:11 pm
#132009
Thanks for your advice. I started playing with the routing utility and it looks like I've established audio through the H8000FW and into Logic!
In the Routing Utility, I started off with the preset #14 Firewire AB. I then took Analog in 1 and matched it to Main in 1 (thus replacing its original signal from Firewire in 1). Firewire 2-8 are still going into Main in 2-8. The remainder of the routing is the same as #14.
However, when I bypass the Eventide, I only hear back the dry signal out of my right speaker. How do I get my left speaker to play back the dry signal as well?
