Home Forums Products Rackmount Need Help Routing H8000FW with audio in Logic 9! Reply To: Need Help Routing H8000FW with audio in Logic 9!
#132010
    Sounds like some progress – good !
    Assuming your H8000 is set for Relay Bypass, when bypassed you'll only get out what you put in. It sounded like you were giving it a mono feed, in which case you'll get a mono output. If this is not the case, what is your analog input and how is it connected ?
