Home › Forums › Products › Rackmount › Can I route the signal like this in the H8000fw? › Reply To: Can I route the signal like this in the H8000fw?
September 29, 2010 at 10:24 pm
#132019
Fine many thanks guys!
I wonder also if it is possible to use the firewire connection on my setup since I have already a USB interface as the heart of my system. I run it in ASIO and use Sonar Producer 8.5 on a PC.
I know it is not possible (or don't know how!) to run two asio driver at the same time in Sonar but will I be able to send audio to and from the H8000fw via firewire (as extrenal loop) without conflictiong with my main interface, which is a VS700R?
