Reply To: Can I route the signal like this in the H8000fw?
Home Forums Products Rackmount Can I route the signal like this in the H8000fw? Reply To: Can I route the signal like this in the H8000fw?
#132020
The FireWire driver will appear as either ASIO or WDM. Given that you probably don't want the WDM you then hit the ASIO limitations.
You may be better off using ADAT or AES to talk to the PC.
