Home Forums Products Rackmount Some routing questions Reply To: Some routing questions
#132032
    Our massive software department has swung into action and found the problem – the old stuff was not being fully cleared before loading the new. We'll have a new version on the Web Site in a week or two – watch this forum for info.
    There is also a partial workaround – load a very full routing, then "marquee select" the lines by clicking and dragging with the mouse, then use the delete x> key to delete them. This will give you a blank palette upon which you can draw that can be saved and reloaded.
    We also found the saved files, so that you can delete them if you want. They are in:
    <user>/Library/Preferences/Eventide/EventideRoutingUtility/H8000FW
