Home Forums Products Rackmount Stereo preset image Reply To: Stereo preset image
#132056
    starman:
    can you sugget me how  can i change the routing so that it will feeds both the dsp inputs
    Either
    Spend time reading the User Manual. This is always a good thing, but not everybody has that time.
    OR
    1) Load the "Analog A-B" routing you were using earlier
    2) setup/dsp a
    3) arrow down 4 times so that the line ending "IN2" is highlighted.
    4) press down arrow on numeric keypad once to that line reads "analog in 1 -> IN2"
    This will give you analog input 1 connected to the first two inputs (IN1 and IN2)on dsp A, which should be what you want.
    If you wanted to use (say) 4 channel presets, you could similarly connect analog 1 to IN3 and IN4.
