Home › Forums › Products › Rackmount › Changing battery on a DSP7000 › Reply To: Changing battery on a DSP7000
#132078
    Sadly there is no battery life meter. You could measure it with a voltmeter – it should be good down to about 2.0V.
    They normally last 7-10 years, depending on use. The battery only supplies power when the unit is switched off.
