Home Forums Products Rackmount PROBLEMS WITH LOOPS Reply To: PROBLEMS WITH LOOPS
#132088
    Dario:
    If i'll understand that this is the reason of my problems, how could I solve it?
    If this is it, you would need some kind of power conditioner or stabilizer. You could try taking your H8000 to another building, which would presumably have a different power situation, and see if it does the same thing.
    Dario:
    the red led hasn't never been highlighted
    I meant that your input signal should occasionally light the red led.
    One other thing – I assume that you have the clock (sync) source set to "internal".
