Home Forums Products Rackmount Changing battery on a DSP7000 Reply To: Changing battery on a DSP7000
#132096
Doug Wellington
    You'll have to remove the firewire board.  There are four screws on the back panel and three screws on the firewire interface board itself.  Undo all seven screws, then gently but firmly lift up on the firewire board to disconnect it from the motherboard.
    Be careful when you reinstall the firewire board!  Make sure you get the pins correctly lined up before pressing the board down into place…
