Home › Forums › Products › Rackmount › Having trouble with updatingto 5.5 using the Flash Card on H8000FW › Reply To: Having trouble with updatingto 5.5 using the Flash Card on H8000FW
#132142
    Eric Zimmermann:
    I consistently get stuck on the prompt of "OUPDATE, awaiting contact"
    At this point, you should get a response from inserting the card. I f not, your problem is probably one of (in order):
    1) Badly written/formatted card
    2) Bad card
    3) Bad adaptor
    4) H8000 hardware problem
    Eric Zimmermann:
    If I understand the directions for 5.5 properly you can only use the CF card to update to 5.5 is that correct?
    Correct
