Home Forums Products Rackmount H 8000 error messages and no longer working Reply To: H 8000 error messages and no longer working
#132182
    Sorry you had a problem, but glad it's now fixed. We've had a few problems with the socket for U106 – current production has the part soldered to the board.
    Also, if you're so inclined, check that all the motherboard mounting screws are present and tight – if they are loose or missing the board can flex if the unit is moved, which can distort the socket.
    Hardware is much harder than software …
