Home › Forums › Products › Rackmount › aes 8 !!!!!! › Reply To: aes 8 !!!!!!
#132279
    Hi Teddy – this is the one I found as well. But – I need the actual pinout of the connector in order to see what your problem is – I'll see if MH will give it to me.
    Until then, my guess is that your MH connector is wired the same way as the H8000's, so if you connect them together you are connecting in to in and out to out, so of course it does not work. If this is the case, you either need a custom cable, or TWO Digi snakes, connected male to female as described earlier.
