Home › Forums › Products › Rackmount › New Tap Tempo Issue! › Reply To: New Tap Tempo Issue!
#132574
    Frank Pearl:
    when i change preset, like Ballerina, the eclipse charges the preset but i can't hear the effect. Always after i push the load button (soft key), it works fine.
    How are you changing the preset ? If you select a preset from the front panel you ALWAYS have to hit <LOAD> to hear it.
