Home Forums Products Rackmount Needs help ! -> Noise problem using the H8000FW in mono guitar rig Reply To: Needs help ! -> Noise problem using the H8000FW in mono guitar rig
#132579
OK, once again (sorry for my poor English):
1.When I bought the Eventide, I've used the XLR female to 1/4" TRS (balanced cable from the Eventide output) to go straight to my amp loop (return), the input was assured with an unbalanced 1/4" TS to 1/4" TS (unbalanced guitar cable)->noise
2.After that, I've used the XLR female to 1/4" TS (unbalanced cable from the Eventide output) to go straight to my amp loop (return), the input was assured with an unbalanced 1/4" TS to 1/4" TS (unbalanced guitar cable) the same input cable as on example 1->noise
Is that more clear?Yes
