Home Forums Products Rackmount Needs help ! -> Noise problem using the H8000FW in mono guitar rig Reply To: Needs help ! -> Noise problem using the H8000FW in mono guitar rig
#132580
    I'm pretty sure that you are going from a balanced output to either an unbalanced cable or an unbalanced input – this is what is causing your problem.
    One way to correctly unbalance the output is to short pin 1 to whichever of the other pins is not being used.
