Home Forums Products Rackmount Needs help ! -> Noise problem using the H8000FW in mono guitar rig Reply To: Needs help ! -> Noise problem using the H8000FW in mono guitar rig
#132599
    There is really nothing more I can add to what I have said before. As the User Manual says, both pins 2 and 3 of the XLR must be connected – otherwise you will get "more noise than signal."
    If you are connecting from XLR to unbalanced 1/4", pin 2 goes to tip, pins 1 AND 3 must go to sleeve.
