Home Forums Products Rackmount ISWITCH module Reply To: ISWITCH module
#132765
    brickman:
    I still cant figure out how to modify the 'select' on the Iswitch module
    Can you explain your problem ? (What do you want to do, what you are you trying, what happens ?).
    I'm going to speculate that your problem is that you are not familiar with the different signal types in Vsig. There is an audio type, which is obvious. A different thing is the control type (of which ISWITCH:select is an example), which is the sort of signal a knob or MIDI would produce (slow). You can convert between audio and control with an A_TO_C and vice-versa with a C_TO_A.
