Home › Forums › Products › Rackmount › Eclipse foot pedal question › Reply To: Eclipse foot pedal question
#132932
jac
    Tip turns off the fx block B, Ring is set as a tap tempo, T/R is set to modulate the delay in someway. when I would stomp on the T/R button, it would alter my delay but would also activate my tip button turn off the fx block B. the top three buttons are set up. tip scrolls up the patch, ring scrolls down the patch. I cant remeber what i set T/R button up as. but, it would act the same way as described above? all the other buttons are working fine. its just the the two T/R buttons causing my woes! Thanks, Nick
