Home › Forums › Products › Rackmount › h8000fw with nuendo 5 › Reply To: h8000fw with nuendo 5
#133008
When you go into the Device Setup – (asio system) menu….you should be able to see a list of ASIO devices attached to your system. So you should be able to see Eventide Dice in the drop down menu in ASIO devices.
