Home Forums Products Rackmount BLACKHOLE 5.1 DO NOT WORK Reply To: BLACKHOLE 5.1 DO NOT WORK
#133070
Synced outputs mean that your H8000 and the Digital System that you connect the digital outputs should run at the same sample rate. So if you are running the Digital outs into AES IN of a digital interface the interface and the h8000 should be at the same sample rate.
What are you connecting the digital outputs to ??
