Home Forums Products Rackmount Eclipse is getting slower during set Reply To: Eclipse is getting slower during set
#133372
    As I said, this is not a known issue, so I cannot be certain that re-initializing the unit will cure it.
    The MF and TF presets are very large, so do take time to load. Is it possible that this is your problem ?
    For example, if you load one of these, it will take time.
    If you then load a few small presets, say, those marked as crossfadeable, are they also slow?
    Is your problem loading time, or response to controls, or what ?
    Does it apply to all presets or just some of them ?
