May 6, 2011 at 8:18 am #107852
Fischermaen
MemberHi everybody,
I have a quite strange problem with my used bought Eclipse (Running software version 4.01).
I have it now for 2 months and I'm doing a lot of programming on during the band rehearsal. After a time period of round about 3 hours, the unit is getting slower and slower. When I press a button (let's say "Parameters" or "Hotkey") it takes longer and longer that the unit responses. When I turn it off and on again, the unit is responding fast again. Is that a thermal problem (the unit is not covered by anything and "breathe") or a hardware issue?
Greets
Andy
May 6, 2011 at 3:04 pm #122064
This is not a known issue. Your first step should probably be to return it to factor defaults (see UM).
May 10, 2011 at 8:27 pm #122075
Fischermaen
MemberThanks for your fast response.
Are you sure, that resetting to factory defaults will solve that problem? The eclipse is always fast, when i turn it on. It's getting slower durig a period of appr. 3 hours. Then I switch it off and on again – and, voilá – it's as fast as before.
Is there a known bug in one of the presets simulating ModFactor and TimeFactor? It occurs to me, that the problem is coming up, when I use large presets.
Greetings Andy
May 11, 2011 at 3:22 pm #133372
As I said, this is not a known issue, so I cannot be certain that re-initializing the unit will cure it.
The MF and TF presets are very large, so do take time to load. Is it possible that this is your problem ?
For example, if you load one of these, it will take time.
If you then load a few small presets, say, those marked as crossfadeable, are they also slow?
Is your problem loading time, or response to controls, or what ?
Does it apply to all presets or just some of them ?
May 12, 2011 at 6:28 am #133386
Fischermaen
MemberI know that large presets take longer time to load. That was only a suggestion what might be the reason for the eclipse getting slower and slower responding. Every press on a Hotkey, Setup-Key, or something else will give a slow response. It seems that my good ol' eclipse is working hard on something else. Even when I load a small preset that will not change that behavior. When I switch off the eclipse and on again, it is responding fast.
May 12, 2011 at 3:25 pm #133388
Sorry – no further ideas.
If you've tried returning it to factory defaults and this has had no effect, it probably needs to be looked at. Try a dealer or support@eventide.com.
