Home › Forums › Products › Rackmount › Orville V3.002 Software Update ~> E100 (Open Command Ack Error 100) › Reply To: Orville V3.002 Software Update ~> E100 (Open Command Ack Error 100)
May 12, 2011 at 7:31 pm
#133391
Glad you got it working !
The error you show may be due to a communications problem. USB-serial converters seem to be a bit variable, especially at high data rates. You could try and reduce the "MIDI/sysex speed" parameter – this might help if the link is being overwhelmed.
Otherwise, you can always download the Vsig database from the Vsig support page on our Web Site.
http://www.eventide.com/AudioDivision/Support/Harmonizers%20and%20Rack%20Products/VSig.aspx
