Home Forums Products Rackmount VSig (or VSigX): Converting Presets from Stereo to Mono Reply To: VSig (or VSigX): Converting Presets from Stereo to Mono
#133708
jcshirke
Thanks a lot, Daniel.
I've basically copied exactly what you did in the Vintage Delay algorithm. The only difference I can see is that my mixer module has two additional (blue) control field on it, and one user object (magenta) field. Is that okay, or should I change (or delete?) them?
I would attach a screen shot, but I don't see any way to do so.
Hopefully I'll be able to do the same thing with the 2 x 2290 preset. It looks a lot more complex (the algorithm, that is), and there are 4 outputs. I don't know if that changes anything??
I got some advice from another Eventide user, and he said that I should reduce the input of the 2 x 2290 preset (after I add the mix module) to -6db. Where/how do I make that change?
Thanks,
Jeff
Thanks,
Jeff
