Home Forums Products Rackmount VSig (or VSigX): Converting Presets from Stereo to Mono Reply To: VSig (or VSigX): Converting Presets from Stereo to Mono
#133709
jcshirke
    Daniel,
    There are 4 inputs and 4 outputs in the 2 x 2290 patch. Is there a way to take all four inputs and add them to a mixer module? Or do I have to use two mixer modules (one for inputs 1 and 2, the other for inputs 3 and 4) and then use a third mixer module to mix those outputs together?
    Likewise with the 4 outputs. Can 1 add module at the end of the algorithm send the signal to all 4 outputs? Or do I want to somehow reduce the outputs down to 2?
    I can send you this algorithm file if you don't have it on your Eventide. I would need your email, if you want to message me. Or write me at jcshirke AT gmail DOT com
    Thanks,
    Jeff
