Home Forums Products Rackmount When will H8000 Save audio samples to card? Reply To: When will H8000 Save audio samples to card?
#133938
    Typically, if there is no help file for a module, you should not use it, as it is experimental or otherwise unsupported.
    My understanding is that only SAMPLER saves to a CF card.
    Load and Save in SIMPSAMP appear to load/save the audio data to internal flash memory. I would suggest that you not  use this capability – don't know where it puts it.
    Can't really tell you anything more – probably best that you stick to the documented and supported modules.
