Home Forums Products Rackmount Fatal H8000 Errors – possible defective Unit Reply To: Fatal H8000 Errors – possible defective Unit
#133984
    Eventide honors warranties on used units, so if yours is still under warranty (see UM for warranty info) and you think that there is something wrong with it, you should contact support@eventide.com.
    Otherwise, not sure what you are looking for. If reinitialization does not clear the error messages, this would suggest a hardware problem and you should contact support@eventide.com.
