Home › Forums › Products › Rackmount › Harmonizer Pitch Issue › Reply To: Harmonizer Pitch Issue
January 17, 2012 at 6:05 pm
#134159
bomer:
Maybe the harmonizer works better on pure tones without "pitch bending".
Probably so – the diatonic expects you to sing in key, and shifts within that key. If you bend a note, it will try and shift it to the nearest note in key – obviously there will be points between notes where it may get confused ..
