Home Forums Products Rackmount Recommended Cables for ADAT Reply To: Recommended Cables for ADAT
#134276
zap
    So far the rocketfish cables fit the best but only if you tape some slack of the cable to the upper back part of your case or rack so that there is no lean in any direction out of the Adat socket – because overnight the cables will come out if leaning downwards.
    This is turning into a farce.   No cables will latch properly clicked in other than these entry level chinese optical cables I found at some surplus store for 7 bucks.
    Can Eventide please provide a reasonable solution here because this is an important matter for some of us.
