Home Forums Products Rackmount Problems with 5.6B OS Reply To: Problems with 5.6B OS
#134522
    This is not monolithic on 5.6 – maybe it should be. I'll look into it. Can you give me any more ?
    Are you using internal or external sync ?
    UPDATE: this one should not be a problem – it uses 55% of the dsp. Obviously it is a problem for you, but can't immediately see why.
    If you haven't, can you let the tests run over night or longer ?
