Home › Forums › Products › Rackmount › H8000FW: are 1/4 inch in/out jacks balanced when TRS plug is used? › Reply To: H8000FW: are 1/4 inch in/out jacks balanced when TRS plug is used?
May 18, 2012 at 3:12 pm
#134546
Assuming you are referring to the DB25 on the back of the H8000FW, this is truly AES. The same connector can also be used for analog, but not by us.
