Home › Forums › Products › Rackmount › H8000FW: are 1/4 inch in/out jacks balanced when TRS plug is used? › Reply To: H8000FW: are 1/4 inch in/out jacks balanced when TRS plug is used?
May 21, 2012 at 6:33 pm
#134556
Sorry this got so confusing – the routing I am looking at is: Switchcraft StudioPatch 9625 DB25 outputs to H8000FW analog inputs (on combo jacks). Those channels on the patch bay are fed by other analog lines.
I had a spare DB25<->TRS snake, and wanted to know if this would preserve balance if the TRS was connected to the H8000FW inputs (would have avoided purchasing a DB25<->XLRM snake). Seems it does not so I got an additional DB25<->XLRM snake for that.
Understood that the DB25 connect on the H8000FW is dedicated to AES.
Thanks,
Rick
