Home › Forums › Products › Rackmount › eclipse message error › Reply To: eclipse message error
May 30, 2012 at 10:09 pm
#134585
Robert Tiffin:
I have the same thing hapening sometimes.It fixes itself and everything runs smoothly.What is this?
Your new battery may be no good. Or, if it runs OK for a while after a battery change, and then goes bad again, you may have a hardware problem that is running down the battery – if so, contact support@eventide.com
I suspect that your other problems are symptoms of the main memory issue.
