Home › Forums › Products › Rackmount › Eclipse Volume Issues? › Reply To: Eclipse Volume Issues?
May 31, 2012 at 11:37 pm
#134592
The only solution for me now is the boss ls2 line selector. Problem is that the dsp bypass is louder than many effects. When you select Bypass while Program Change you hear for a short while the louder bypassed signal. I would suggest an Update where you can select the Wet/dry Mode, like for Studio work ( the way it is now ) and for stompbox work, where the 50/50 Wet/dry keeps the Original Signal at the same volume as the 100% Dry Setting. Funky that they did it right with the stompboxex and even with the Stompbox Algos in the eclipse, where they integrated a more guitar friendly mix knob in the algorithm.
