Home › Forums › Products › Rackmount › Another Eclipse or just buy 2 or 3 stompboxes? › Reply To: Another Eclipse or just buy 2 or 3 stompboxes?
#134655
    Depends a bit on what you want. If you want three different effects at the same time, probably in series, you'd be better with the stomps. If, on the other hand, you want a much wider choice of effects, with only one or two active at any point, the Eclipse might be a better idea.
