Home Forums Products Rackmount Last results with Eventide H8000fw big verbs Reply To: Last results with Eventide H8000fw big verbs
#134716
    I think if you are running with A || B and thru you will get a lot of dry signal. Try manually setting up the routing so you only get DSPB.
    Also, when checking for bangs, run with no inputs, otherwise you can't know from where the bangs come (any bang going into  a big reverb will be "effected").
