Home › Forums › Products › Rackmount › H8000 problem: comb filter because of dry signal › Reply To: H8000 problem: comb filter because of dry signal
September 14, 2012 at 7:02 pm
#134885
Again, check your routing. If you have a parallel routing, and you bypass dsp B, depending on the bypass mode, you may get dry signal.
