Home › Forums › Products › Rackmount › H8000 problem: comb filter because of dry signal › Reply To: H8000 problem: comb filter because of dry signal
September 14, 2012 at 10:21 pm
#134890
You're right – the output mixers are set up so that the reverb signal is added to a full level dry signal. As a result, this one would not be suitable for use in an effect send/return environment.
You could fix it this by setting the mixer dry gains to 0.
