Home › Forums › Products › Rackmount › Adat Routing at 96Khz › Reply To: Adat Routing at 96Khz
October 26, 2012 at 3:22 pm
#134957
…this morning we get big trouble with the H8000fw. ( now it fixed hopefully !).
What happens :
There is a big Problem while changing from 44,1/48 and 88/96 Muxxed via Adat.
This morning the whole AudioEngine was broken, necessary what routing you use.
Everything dead. We fixed this in " Services " – " clear setup " and " fix internal"
Make a backup from your Routings ! After that everything is fine.
Please fixed that.
PS. if you load the Muxxed Adat Routing in the Routing Utility or try to build this up in this tool you get total error with OSX 10.7.3.
