Home Forums Products Rackmount SP/DIF challenges Reply To: SP/DIF challenges
#135094
    I assume your saffire is both sending and receiving to and from the Eclipse.
    But, I see that your Eclipse is set to int44 – does this mean that the Eclipse is the clock master ? This seems unlikely, as otherwise the saffire would track it when you set it to 48.
    My guess is that the saffire is the clock master, and thus the Eclipse clock should be set to "DigIn" rather than "int" so it will track it.
