Home › Forums › Products › Rackmount › Eclipse Volume Issues? › Reply To: Eclipse Volume Issues?
March 20, 2013 at 8:16 am
#135305
the best way to use the eclipse in a live guitar rig is with a a parallel mixer. I use a radial mix plus in the FX loop of new Vox Ac30, but any amp with a series fx loop will do. Set the wet dry to 100 %, boost the analog outs by around 3 – 4 db, reduce the inputs by approx 15 db (depending on the amp loop). Use the output level in each preset to blend the eclipse with the "dry" signal in the fx loop, cheers
