Reply To: DSP7000 in a stereo guitar amp setup
Home Forums Products Rackmount DSP7000 in a stereo guitar amp setup Reply To: DSP7000 in a stereo guitar amp setup
#136096
homer
Thanks for the confirmation.
Now as you mention the H8000FW: Is it possible to have the WET/DRY path rerouted  in that unit? Are you sure?
BTW here is a workaround, not elegant but working….
Add a stereo mixer module in VSIG to the algorithm and mix IN1 directly with the output of the FX block which would usually feed OUT2. Now feed that finally into OUT2. The Wet/Dry level for OUT2 is now controlled by the mixer module.
Only thing that you need to take care of is to make sure that the mix level is in line with the global WET/DRY parameter in the levels menue.
BTW is there any way to access that global WET/DRY parameter in VSIG to have these parameters linked?
THX
