Home Forums Products Rackmount Newbie questions on Aux – Orville hookup Reply To: Newbie questions on Aux – Orville hookup
#136170
    gareth33:
    factory routings
    Look in the UM under "Storing and Loading Routing Configurations"
    gareth33:
    I couldn't find the Routing Utility
    Look on the H8000 Support Page
    gareth33:
    What do I do internally with the other In as specified in the identifier '24'?
    In this case you could route your mono in to both DSP A 1 and 2.
    gareth33:
    In this case there are 4 outs
    Each main output can have two mixed signals. So, you could mix your 4 DSP outputs to a stereo final output. But note that a 24 preset is probably meant to be used with a quad output – no reason why you should not mix it to stereo if you like the results, but …
    So, to conclude, I recommend:
    1) Study of the routing section in the UM.
    2) Study of the factory routing presets
    3) Use of the Routing Utility.
    Orville is a complex and sophisticated box, and the flexibility of its routing capabilities can appear difficult until you "get the idea."
