Home Forums Products Rackmount HELP WITH HISS NOISE ! Reply To: HELP WITH HISS NOISE !
#136269
    Nothing wrong really, you are just not giving it enough level.The Eclipse is designed to accept a nominal +4dBm line level, with 20dB of headroom above this for peaks. It sounds like you are giving it less – the meter readings you give suggest a peak of +4, rather than a nominal +4.
    Set the input gain higher, and then turn down the output gain by the same amount. All will be fine.
