Home Forums Products Rackmount VSigfile no longer working – Comms issue? Reply To: VSigfile no longer working – Comms issue?
#136271
ThreeFingersOfLove
    Nick,
    I think I have solved the problem. I managed to load the sigfile database from the H8000-FW to my laptop and all these presets can now be opened within VSig. I think what caused the memory overflow is that I had many algorithms open already, when I closed these and restarted VSig, everything worked just fine.
    I do think however, that I have found a bug. When I use the numeric keypad to select an algorithm and then press the button instead of the "Ent" it tries to load the intended preset directly, but fails and stays at whatever preset was before. So, I need to type the number, hit and then hit .
    Or is this intentional?
