Reply To: H8000/EveNet issues
Home Forums Products Rackmount H8000/EveNet issues Reply To: H8000/EveNet issues
#138014
rmccomb
I had a large number of crashes with the Routing Utility program, it turns out you don't need to use the serial COM port at all – set Comms Preferences to MIDI: Input and Output set to Eventide Dice.
It works a million times faster – through the Firewire connection I believe.
The dialog box for this is bit non-standard and confusing – you select non-MIDI-Serial by selecting the tab, then OK. (A radio button group would be more standard).
Same deal for VSig.
Cheers,
Rob
