Home Forums Products Rackmount 4000 analog I/O question Reply To: 4000 analog I/O question
#138968
    Eventide might or might not have the board – it depends on the age of the unit. Also, be warned, it may be something else – just because there is no audio, it does not mean that the audio board îs at fault.
    If you want to continue with this, your best bet might be to send it in for service. If it is not electrically damaged, this might be the best solution.
